Verge3D 4.0 migration guide
In this guide you will find info on how to perform migration from Verge3D 3.XX to major 4.0 release.
Short Memo
In most cases, these steps are sufficient:
- Install Verge3D 4.0.
- Launch App Manager. When it asks to enter a new application directory, leave default or choose existing (e.g verge3d_blender/applications).
- Update your apps in App Manager using build-in updater.
- Reexport your Blender/3ds Max/Maya assets.
- Resave Puzzles.
Major Changes
Directory Split
- Verge3D software files: engine modules, App Manager, exporter plugins, documentation etc
- Application files
- Configuration files
- Temporary directory for Sneak Peek exports
Now we store them separately:
- Verge3D software files now installed in the separate read-only directory (e.g Program Files on Windows).
- Application files now stored in the explicitly selected directory (e.g Documents\verge3d_apps).
- Configuration files go to system-specific place (e.g AppData\Roaming\Soft8Soft\Verge3D for Blender).
- Temporary directory go to system-specific place (e.g AppData\Local\Temp) and automatically cleared up on exit.
Puzzles Library
So you should copy the file called my_library.xml from e.g verge3d_blender/puzzles of your old Verge3D 3.X installation to your applications folder.
App Manager Templates
Puzzles Plugins
