Coordinate Systems
Verge3D
Blender
3ds Max
Maya
Coordinate System Conventions
Bullet/Ammo.js | Y-up | right-handed | same as in Verge3D |
Houdini | Y-up | right-handed | same as in Verge3D |
Maya | Y-up | right-handed | same as in Verge3D, configurable to Z-up right-handed |
OpenGL/WebGL/glTF | Y-up | right-handed | same as in Verge3D |
Three.js | Y-up | right-handed | same as in Verge3D |
WebGPU | Y-up | left-handed |
