Aggressive Optimizations
Cut off features slowing you down!
  • Use smaller shadow maps (see here why)
  • Use just one light that casts shadows
  • Use Basic or Bilinear shadow filtering instead of PCF (Poisson Disk) / ESM shadow (check out this info)
  • Never cast shadows from the point lights!
Disable post-processing
Disable HDR rendering
Get rid of light probes
  • Keep IBL map but remove all light sources. For better performance, you might also switch IBL mode to "Light Probe + Cubemap".
OR:
Set IBL cubemap size to 256
Set View Transform from Filmic to Standard
No hardcore anti-aliasing
You'll surely get some artifacts with this compression algorithm, but the memory and network bandwidth savings are truly enormous (check out the lamp from the Khronos guys)! The instructions are here.
Emission shading only
