Coordinate Systems
Verge3D
Blender
X (Blender) ->  X (Verge3D)
Y (Blender) -> -Z (Verge3D)
Z (Blender) ->  Y (Verge3D)
3ds Max
On the other hand, Maya, most game engines, graphics APIs, and of course Verge3D use different approach. The screen becomes a 2D plain which uses X/Y coordinates to position flat images, while Z coordinate adds depth to the scene. That's why the buffer that stores pixel depth is called Z-buffer and the issue with limited depth precision is called Z-fighting.
Maya
Coordinate System Conventions
3ds Max Z-up right-handed
Blender Z-up right-handed
Bullet/Ammo.js Y-up right-handed similar to Verge3D
Cinema4D Y-up left-handed
DirectX Y-up left-handed
Houdini Y-up right-handed similar to Verge3D
Maya Y-up right-handed similar to Verge3D, configurable to Z-up right-handed
Three.js Y-up right-handed similar to Verge3D!
Unity Y-up left-handed
Verge3D Y-up right-handed
WebGPU Y-up left-handed
