CyberFox Save/Load URL plugin
Revision as of 14:36, 5 August 2021 by CyberFox (talk | contribs) (Created page with "This plugin provides functionality for convenient reading and writting the link parameters. With incredible ease, you can take your apps to the next level. Saving all the...")
Saving all the necessary parameters to a link and an easy way to read back.
Check out the demo here! - https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:beda483d65/applications/url_demo/index.html
Puzzles:
Puzzles: read link
Puzzles: get link parameter
Puzzles: set link parameter
Installation options
1. Unpack the archive
Changelog
1.0
  • Basic functionality
