Creating installers for Verge3D plugins
By using NSIS you can wrap your plugins to user-friendly installers. Contrary to manual ZIP distribution, installers search for Verge3D distros and automatically copy plugin files to required plugin directory.
NSIS creates Windows-only installers. For macOS and Linux, ZIP is still the preferred way to distribute your plugins.
Unicode true
SetCompress off
SetCompressor /SOLID lzma
!include "MUI2.nsh"
RequestExecutionLevel highest
!include LogicLib.nsh
# interface Settings
!define MUI_ABORTWARNING
# pages
!insertmacro MUI_PAGE_WELCOME
!insertmacro MUI_PAGE_FINISH
Section
SectionIn RO
SetOutPath "$INSTDIR"
File LICENSE.txt
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
SectionEnd
Section "Uninstall"
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
Delete "$INSTDIR\*.*"
RMDir "$INSTDIR"
SectionEnd
