Creating installers for Verge3D plugins
By using NSIS you can wrap your plugins to user-friendly installers. Contrary to manual ZIP distribution, installers search for Verge3D distros and automatically copy plugin files to required plugin directory.
Unicode true
SetCompress off
SetCompressor /SOLID lzma
!include "MUI2.nsh"
RequestExecutionLevel highest
!include LogicLib.nsh
# interface Settings
!define MUI_ABORTWARNING
# pages
!insertmacro MUI_PAGE_WELCOME
!insertmacro MUI_PAGE_FINISH
Section
SectionIn RO
SetOutPath "$INSTDIR"
File LICENSE.txt
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
SectionEnd
Section "Uninstall"
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
ClearErrors
${IfNot} ${Errors}
${EndIf}
Delete "$INSTDIR\*.*"
RMDir "$INSTDIR"
SectionEnd
Modify the script by replacing "Example Plugin" with the actual plugin name. Also choose proper name for the EXE file "example-plugin.exe", specify company name instead of "YourCompany", edit text fields which will be displayed to the user.
You also need to place "LICENSE.txt" file to the plugin directory. This file will be displayed to the user before the actual installation starts.
Done, check out the EXE file generated along the plugin directory. Fill free to share it with your users!
