Verge3D 4.0 migration guide
Short Memo
- Install Verge3D 4.0.
- Re-save Puzzles.
Major Changes
Removal of deprecated puzzles
Directory Split
- Application files.
- Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
- Blender 2.80-2.82
- 3ds Max 2019
- Maya 2018
Removed deprecated Puzzles-based AO
Changed Verge3D Network file hierarchy
In order to migrate to new URLs without braking the older links, you might use the following trick.
- Go to the Verge3D user directory, and create a folder named "applications".
- Create a subfolder inside the applications folder called "MyAwesomeApp".
<head>
</head>
- Launch the App Manager, and upload the "applications" app to Verge3D Network .
