Verge3D 4.0 migration guide
Revision as of 06:43, 15 June 2022 by Alexander (talk | contribs)
Short Memo
  1. Install Verge3D 4.0.
  5. Re-save Puzzles.
Major Changes
Removal of deprecated puzzles
Directory Split
  2. Application files.
  3. Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
  • Blender 2.80-2.82
  • 3ds Max 2019
  • Maya 2018
Removed deprecated Puzzles-based AO
