Verge3D 4.0 migration guide
Short Memo
- Install Verge3D 4.0.
- Re-save Puzzles.
Major Changes
Removal of deprecated puzzles
Directory Split
- Application files.
- Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
- Blender 2.80-2.82
- 3ds Max 2019
- Maya 2018
No custom settings for glTF-compatible materials
To make glTF-compatible materials lightweight and compatible with various tools, we removed custom Verge3D-based settings from such materials. Among these settings: Shadow Cast, Shadow Receive, Depth Write, Depth Test, and Dithering. To enable these features you need to switch off the glTF Compatible checkbox, or use Puzzles/JavaScript.
