Verge3D 4.0 migration guide
Short Memo
- Install Verge3D 4.0.
- Re-save Puzzles.
Major Changes
Removal of deprecated puzzles
Directory Split
- Application files.
- Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
- Blender 2.80-2.82
- 3ds Max 2019
- Maya 2018
