Common gotchas with Verge3D
Huge shadow maps
Swapping the object on click
Say you need to replace some object by another considering they both occupy the same place, e.g swap CubeGold by CubeSilver and vice versa. Most evident way would be using 2 when clicked puzzles:
This won't work since both events happen right after another. So the first event handler will switch to CubeSilver, then the second will switch back to CubeGold. Correct approach would be to delay actions performed by puzzles:
