Verge3D 4.0 migration guide
Short Memo
- Install Verge3D 4.0.
- Re-save Puzzles.
Major Changes
Directory Split
- Application files.
- Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
