Verge3D 4.0 migration guide
Short Memo
- Install Verge3D 4.0.
- Re-save Puzzles.
Major Changes
Directory Split
- Application files.
- Configuration files.
- Temporary directory goes to another system-specific folder (e.g. AppData\Local\Temp) and automatically cleared up on exit.
Puzzles Library
So you should copy the file called my_library.xml from e.g verge3d_blender/puzzles of your old Verge3D 3.X installation to your applications folder.
App Manager Templates
Puzzles Plugins
