Verge3D 4.0 migration guide
Short Memo
- Install Verge3D 4.0.
- Launch App Manager. When it asks to specify a new application directory, leave it by default or choose some existing folder (e.g verge3d_blender/applications).
- Update your apps in App Manager using build-in updater.
- Reexport your Blender/3ds Max/Maya assets.
- Resave Puzzles.
Major Changes
Directory Split
- Application files.
- Configuration files.
Now we store them separately:
- Verge3D software files now installed in the separate read-only directory (e.g Program Files on Windows).
- Application files now stored in the explicitly selected directory (e.g Documents\verge3d_apps).
- Configuration files go to system-specific place (e.g AppData\Roaming\Soft8Soft\Verge3D for Blender).
- Temporary directory go to system-specific place (e.g AppData\Local\Temp) and automatically cleared up on exit.
Puzzles Library
So you should copy the file called my_library.xml from e.g verge3d_blender/puzzles of your old Verge3D 3.X installation to your applications folder.
App Manager Templates
Puzzles Plugins
