NPOT Textures
- 1000x500
- 1200x800
- 1920x1080
- 500x1
- 512x512
- 2048x1024
- 4096x4096
- 128x1
WebGL 1.0
- Increased app loading time, because texture conversion takes time.
- More memory consumption.
- Reduced texture quality.
- Wasted texture space as the image is re-scaled by Verge3D to get the closest POT texture.
WebGL 2.0
- NPOT textures cannot be compressed
Avoid using NPOT textures in Verge3D applications!
