Known Verge3D Limitations
Revision as of 14:07, 20 September 2021 by Alexander (talk | contribs) (→Raycasting to skinned objects)
When two or more clipping planes intersect with each other, you can see the following artifacts similar to Z-fighting.
Camera Scaling
