Coordinate Systems
Verge3D
Blender
3ds Max
On the other hand, Maya, most game engines, graphics APIs, and of course Verge3D use another approach. Your screen becomes a 2D plain which uses X/Y coordinates to position flat images while Z coordinate adds depth to your scene. That's why the buffer that stores pixel depth is called Z-buffer and the issue with limited depth precision is called Z-fighting.
Maya
Coordinate System Conventions
Bullet/Ammo.js | Y-up | right-handed | |
Houdini | Y-up | right-handed | |
Maya | Y-up | right-handed | configurable to Z-up right-handed |
OpenGL/WebGL/glTF | Y-up | right-handed | |
WebGPU | Y-up | left-handed |
