Coordinate Systems
Verge3D
Blender
3ds Max
Now it's time for history lesson. Both Blender and 3ds Max use coordinate system which were common in early 90's. This convention is typical in architecture - you start modelling from the floor plan which uses X/Y coordinates and then extrude upwards (or downwards). Maya, most game engines, graphics APIs, and of course Verge3D use another approach: your screen is a plain with X/Y coordinates while Z is the scene depth.
Maya
Coordinate System Conventions
Bullet/Ammo.js | Y-up | right-handed | |
Houdini | Y-up | right-handed | |
Maya | Y-up | right-handed | configurable to Z-up right-handed |
OpenGL/WebGL/glTF | Y-up | right-handed | |
Verge3D | Y-up | right-handed |
