Coordinate Systems
Verge3D
Blender
3ds Max
Autodesk 3ds Max uses right-handed coordinate system with Z axis pointing in the up direction. This convention is similar to Blender.
Maya
Coordinate System Conventions
Bullet/Ammo.js | Y-up | right-handed | |
Houdini | Y-up | right-handed | |
Maya | Y-up | right-handed | configurable to Z-up right-handed |
OpenGL/WebGL/glTF | Y-up | right-handed | |
Verge3D | Y-up | right-handed |
