Known Verge3D Limitations
General limitations
Camera Scaling
HiDPI Compositing Limitations
Export multiple animation clips for the same object
Deep Collection Instancing
Material animation
Physics
Postprocessing
Rotation animation
Textures
XRef Objects
Verge3D for Maya limitations
View Transform
