Blender 4.2 migration guide
Revision as of 08:37, 19 February 2025 by Alexander (talk | contribs)
Transparency
Redundant Nodes
When you open older scenes in Blender 4.2 you'll a bunch of new nodes added to the end of the shader graph:
These should be safely removed. Easiest way to do so would be delete "EEVEE" part entirely and switch the "Cycles" output to "All".
Shadows
Ambient Occlusion
Light Probes
