Known Verge3D Limitations
Revision as of 12:53, 1 June 2023 by Nury (talk | contribs) (Verge3D for Blender limitations additions: 1) rotation animation must be on all axes 2) UDIM textures are not supported yet)
General limitations
Camera Scaling
HiDPI Compositing Limitations
Deep Collection Instancing
Material animation
Physics
Postprocessing
Rotation animation
Rotation animation must be on all axes, otherwise there may be unpredictable results. Correct rotation animation example.png
Textures
XRef Objects
Verge3D for Maya limitations
View Transform
