Coordinate Systems
Verge3D
So, it does not matter which Verge3D flavor you use: for Blender, 3ds Max, or Maya. In all these cases the internal coordinate system would be the same - Y-up.
Blender
3ds Max
Now it's time for history lesson. Both Blender and 3ds Max use coordinate system which were common in early 90's. This convention is typical in architecture - you start modelling from the floor plan which uses X/Y coordinates and then extrude upwards (or downwards). On the other hand, Maya, most game engines, graphics APIs, and of course Verge3D use different approach. The screen becomes a 2D plane which uses X/Y coordinates to position flat images, while Z coordinate adds depth to the scene. That's why the buffer that stores pixel depth is called Z-buffer and the issue with limited depth precision is called Z-fighting.
Maya
Coordinate System Conventions
Bullet/Ammo.js | Y-up | right-handed | same as in Verge3D |
Houdini | Y-up | right-handed | same as in Verge3D |
Maya | Y-up | right-handed | same as in Verge3D, configurable to Z-up right-handed |
OpenGL/WebGL/glTF | Y-up | right-handed | same as in Verge3D |
Three.js | Y-up | right-handed | same as in Verge3D |
WebGPU | Y-up | left-handed |
