Installing Maya on Linux
Jump to navigationJump to searchThis article is a stub. You can help Verge3D Wiki by expanding it.
Maya 2023 on Fedora 36
Install dependencies:
sudo dnf install libnsl sudo dnf search libpng15 sudo dnf install libGLU sudo dnf install libffi3.1
Run with:
maya --single-process
Maya 2022 on Ubuntu
See here.
Fixing issue with duplicated icons
StartupWMClass=maya.bin
Reload
