Known Verge3D Limitations
General limitations
Camera Scaling
HiDPI Compositing Limitations
Deep Collection Instancing
Physics
Blender Physics properties are not exported and as such not supported in Verge3D. Use puzzles to perform physical simulations in your apps.
