Common gotchas with Verge3D
Huge shadow maps
Swapping object on click
There will be one of the two consequences of it.
Case #1 (bad). You won't be able to load your scene, since your app expects the compressed asset (e.g my_awesome_app.gltf.xz) which is unavailable. Case #2 (even worse). You have file called my_awesome_app.gltf.xz in your app which you exported using
