Common gotchas with Verge3D
Revision as of 13:21, 30 May 2022 by Alexander (talk | contribs)
Huge shadow maps
Swapping object on click
Say you need to perform 10 different actions for 5 objects on your scene. Most straightforward solution to that problem would be using copy-paste feature:
This approach is quite time-consuming and it's really hard to maintain such scenario. With procedures you can make this script less cumbersome:
And by using object lists the logic can be improved even further:
