Tips for Verge3D devs
or to enable FPS counter:
// DONT FORGET TO REMOVE IT!
material.map = texture;
planeMesh.position.x = 6;
Code Indentation Style
The K&R style, 4 spaces:
function someFun() {
    const someConst = 10;
    const alwaysTrue = true;
        if (alwaysTrue) {
            console.log(`Hello ${i}!`);
Key Triplets
Short Links
3ds Max SDK requirements
See here.
