NPOT Textures
- 1000x500
- 1200x800
- 1920x1080
- 500x1
- 512x512
- 2048x1024
- 4096x4096
- 128x1
Why NPOT texture are bad for real-time 3D?
WebGL 1.0
Older hardware/browsers, which support only WebGL 1.0 standard, do not handle NPOT textures well. For example, you can't use advanced filtering on them. As such, all such textures will be resized to nearest power-of-two dimensions. This will result to:
- Increased app loading time, because texture convertion takes time.
- More memory consumption.
- Reduced texture quality.
WebGL 2.0
Do not use NPOT texture in Verge3D applications!
