Known Verge3D Limitations
Jump to navigationJump to searchTwo or more clipping planes parallel to each other
When two or more clipping planes intersect with each other, you can see the following artifacts similar to Z-fighting.
Camera Scaling
Raycasting to skinned objects
If some skinned object moves out of its bounding (sphere of box), raycasting will be fail to detect its new position.
