Coordinate Systems
Revision as of 15:46, 9 September 2021 by Alexander (talk | contribs)
Verge3D
Blender
X (Blender) ->  X (Verge3D)
Y (Blender) -> -Z (Verge3D)
Z (Blender) ->  Y (Verge3D)
3ds Max
Autodesk 3ds Max uses right-handed coordinate system with Z axis pointing in the up direction. This convention is similar to Blender.
Maya
Coordinate System Conventions
3ds Max Z-up right-handed
Blender Z-up right-handed
Cinema4D Y-up left-handed
DirectX Y-up left-handed
Houdini Y-up right-handed
Unity Y-up left-handed
Verge3D Y-up right-handed
