3D Technologies and Solutions
ART
ATF
BRDF
BSDF
BTDF
Hydra (HD)
Irradiance
LookdevKit
LookdevX
LTC
MaterialX
Mental Ray
MetaSL
Nitrous
3ds Max viewport system.
OGS
OpenPBR Surface
Name of standard shader node for physically based rendering (PBR). Supported starting from 3ds Max 2025.3 and Maya 2025.3.
Radiance
RapidRT
Stingray
