Blender 4.2 migration guide
Revision as of 09:26, 9 July 2024 by Alexander (talk | contribs)
Transparency
Shadows
Ambient Occlusion
Light Probes
In general, the only things we can do now, is to approximate Verge3D rendering so that it is more or less consistent with the Blender viewport.
