Revision as of 20:08, 1 May 2024 by Alexander (talk | contribs) (→‎Beyond glTF 2.0)
With Verge3D it's a completely different story. The framework was designed to be an artist-friendly tool. You just need to have some Blender, 3ds Max, or Maya skills to make any kind of 3D web content with Verge3D. Moreover, it supports features of these modelling suites (cameras, lights, shadows, constraints, animation, etc) natively and strives to make Verge3D renderings look exactly the same. Blender 3ds max maya.png
Code-Less Programming
Beyond glTF 2.0
Biohazard!
App Manager
  • Updating apps.
Verge3D Network
More Neat Things
  • More stable JavaScript API.
  • Cooler documentation.
  • Official tutorial videos to help you get started.
  • Nice forums and Discord channel.
  • Plugins!
  • Out-of-the-box asset compression.
  • Ready-to-use material libraries.
  • Easy integration with HTML builders, such as Webflow.
  • Source-code compatibility with Three.js.
Get Verge3D Now!
