Known Verge3D Limitations
General limitations
Camera Scaling
HiDPI Compositing Limitations
Deep Collection Instancing
Material animation
Physics
Postprocessing
Rotation animation
Textures
XRef Objects
Verge3D for Maya limitations
View Transform
