Aggressive Optimizations
Here is the list of aggressive optimizations that you can use as quick & dirty hacks to boost performance of your apps. All these techniques reduce rendering quality, so use them with caution! Normally, you should always be a patient optimizer and stick to the "official" recommendations specified here and here.
Disable shadows
- Use huge shadow maps (perhaps it's time to reduce their size!)
- Use a lot of shadow sources (stick to just one)
- Use PCF (Poisson Disk) / ESM shadow filtering (choose Basic or Bilinear)
- Cast shadows from the point lights (never!)
Disable post-processing
It's not always about post-processing puzzles. Don't forget about ambient occlusion and outlining which are enabled in the modeling suite!
Disable HDR rendering
I'm sure you never enable it without proper thinking.
Remove reflection cubemaps and planes
Reflection cubemaps affect loading speed, planes affect both loading speed and rendering performance. Both consume GPU memory.
Use either light sources or HDR environment reflections
Stick to one of them:
- Keep light sources (preferably one light) but disable specular environment reflections by switching IBL mode to "Light Probe" which provides only diffuse lighting.
- Remove all light sources. For better performance you might also switch IBL mode to "Light Probe + Cubemap".
Set IBL cubemap size to 256
Set View Transform to Standard
Don't use procedural textures
Except checker maps... The noise (and noise-like) textures are especially bad for performance - stick to the regular image textures with noise pattern.
No hardcore anti-aliasing
You'll surely get some artifacts with this compression algorithm, but memory and network bandwidth savings are enormous (check out this lamp)! The instructions are here.
Emission shading only
