Installing Maya on Linux
Revision as of 14:16, 7 September 2022 by Alexander (talk | contribs) (→Fixing issue with duplicated icons)
Maya 2023 on Fedora 36
Install dependencies:
sudo dnf install libnsl sudo dnf search libpng15 sudo dnf install libGLU sudo dnf install libffi3.1
Run with:
maya --single-process
Maya 2022 on Ubuntu
See here.
Fixing issue with duplicated icons on the launch panel
StartupWMClass=maya.bin
