Installing Maya on Linux
Revision as of 14:13, 7 September 2022 by Alexander (talk | contribs)
Maya 2023 on Fedora 36
Install dependencies:
sudo dnf install libnsl
sudo dnf search libpng15
sudo dnf install libGLU
sudo dnf install libffi3.1
Run with:
maya --single-process
Maya 2022 on Ubuntu
See here.
Fixing issue with duplicated icons
StartupWMClass=maya.bin
Reload
