Creating installers for Verge3D plugins
Revision as of 12:01, 17 August 2022 by Alexander (talk | contribs)
Unicode true
SetCompress off
SetCompressor /SOLID lzma
!include "MUI2.nsh"
RequestExecutionLevel highest
!include LogicLib.nsh
# interface Settings
!define MUI_ABORTWARNING
# pages
!insertmacro MUI_PAGE_WELCOME
!insertmacro MUI_PAGE_FINISH
Section
    SectionIn RO
    SetOutPath "$INSTDIR"
    File LICENSE.txt
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
SectionEnd
Section "Uninstall"
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    Delete "$INSTDIR\*.*"
    RMDir "$INSTDIR"
SectionEnd
