NPOT Textures
- 1000x500
- 1200x800
- 1920x1080
- 500x1
- 512x512
- 2048x1024
- 4096x4096
- 128x1
Why NPOT texture are bad for real-time 3D?
WebGL 1.0
- Increased app loading time, because texture convertion takes time.
- More memory consumption.
- Reduced texture quality.
WebGL 2.0
Avoid using NPOT textures in Verge3D applications!
