Known Verge3D Limitations
When two or more clipping planes intersect with each other, you can see the following artifacts similar to Z-fighting. Possible workaround of this issue would be using only one plane or disabling the "Filled Cross-Section" setting.
Camera Scaling
Raycasting to skinned objects
