Code-Less Programming
Beyond glTF 2.0
Earlier we said that Three.js does not belong to any company officially. Still, the lead developer and main contributor to this software is an employee at Google. Same story is with Babylon.js, another popular WebGL toolkit, which is developed by two Microsoft employees. Of course, there are benefits of being under the umbrella of large corporations. Still there are risks, since the both products are non-profitable and do not affect Google/Microsoft income directly. This situation does not allow to say about stable development, since any activity that does not generate enough cash may get cut at any time.
App Manager
- Updating apps.
Verge3D Network
More
- Cooler documentation.
- Plugins!
