With Verge3D it's a completely different story. The framework was designed to be an artist-friendly tool. You just need to have some Blender, 3ds Max, or Maya skills to make any kind of 3D web content with Verge3D. Moreover it supports features of these modelling suites (cameras, lights, shadows, constraints, animation, etc) natively and strive to make Verge3D renderings look exactly the same.
Code-Less Programming
Verge3D user is just and artist. He can design content, create an app, and then do programming by himself using the visual logic tool called Puzzles. Puzzles is a great tool since it both powerful and easy-to-use.
Beyond glTF 2.0
