3D Technologies and Solutions
Revision as of 09:42, 17 October 2024 by Alexander (talk | contribs)
ART
ATF
BRDF
BSDF
BTDF
Hydra (HD)
Irradiance
LookdevKit
LookdevX
LTC
MaterialX
Standard for interoperable node-based materials. MaterialX graphs can be stored inside USD assets or as a separate XML (.mtlx) files.
Mental Ray
MetaSL
Nitrous
3ds Max viewport system.
OGS
OpenPBR Surface
Name of standard shader node for physically based rendering (PBR). Supported starting from 3ds Max 2025.3 and Maya 2025.3.
Radiance
RapidRT
Stingray
