3D Technologies and Solutions
ART
ATF
BRDF
BSDF
BTDF
Hydra (HD)
Irradiance
Mental Ray
Deprecated ray tracing renderer by NVIDIA. Were used in older versions of 3ds Max, Maya, Revit, Softimage, etc. Replaced by Arnold.
MetaSL
Outdated shading language which were used in 3ds Max (before 2016) and Mental Mill software.
Nitrous
3ds Max viewport system.
OGS
Radiance
RapidRT
Render engine, aka Autodesk RayTracer (ART).
Stingray
A discontinued 3D game engine. Also used as 3ds Max Interactive plugin for older 3ds Max. Node system based on Stingray PBS is supported in 3ds Max, Maya (via ShaderFX editor).
