3D Technologies and Solutions
Revision as of 09:52, 13 September 2024 by Alexander (talk | contribs) (→‎Radiance)
ATF
BRDF
BSDF
BTDF
Hydra (HD)
Irradiance
OGS
Radiance
Radiant flux emitted, reflected, transmitted, or received by a given surface, per unit solid angle per unit projected area. Unit for radiance is watt per steradian per square metre (W·sr−1·m−2).
