Installing Maya on Linux
Maya 2024 on Fedora 39
Install dependencies:
sudo dnf install libnsl sudo dnf install libpng15 sudo dnf install libGLU sudo dnf install mesa-libGLw sudo dnf install mesa-libGLw
Run with:
maya --single-process
Maya 2022 on Ubuntu
See here.
StartupWMClass=maya.bin
