zooom depth
Home Forums Graphics / Blender zooom depth
  • This topic has 6 replies, 4 voices, and was last updated 4 years ago by Emma.
  • #35186
    Emma
    Hi at all,
    A simple question, a question that escapes me and I cannot solve. :mail:
    If in Verge I “zoom” with the mouse wheel, the object disappears. It’s definitely related to the depth of the camera.
    How can I solve?
    As always
    Thanks
    Emma :bye:
    #35188
    You need to change Fer Clipping value of the camera.
    #35195
    Emma
    Thanks Mikhail,
    You know where I can change this value in Blender ?
    In Blender I haven’t changed the values
    Emma :scratch:
    #35214
    GLiFTeK
    That is in the active tools properties. (I believe) Select the camera, then the slide-in menu on the right side of the main camera view window.
    #37313
    Emma
    I’m back on this problem.
    I bring a simple common example.
    If I open Verge demo cube and I walk away with the view (turn wheel mouse), the cube will be partially eaten.
    it’s the same for you too ??
    Thanks
    Emma
    #37316
    visualizer
    Hi
    Increase the camera near & far viewing properties in blender. This will solve it.
    #37328
    Emma
    Ahhhh, found it !!!
    Solved !
    Thanks :good:
