Zooming / transforming code required
Home Forums Programming Zooming / transforming code required
  • #9354
    justkmoo
    Hello, I added “zoom” into the css to make it look like browser-scaling. So that the scene looks more high-quality. But this method will cause other problems like HTML elements messing. Are there any other methods to achieve this zooming goal without messing things up?
    #9364
    Hi, it’s better to directly change the size of the rendering viewport via API. If you have an application in the standard verge3d App Manager, you can add the following lines into the runCode() function in the application’s main js file:
    function runCode(app) {
        // add your code here, e.g. console.log('Hello, World!');
        app.renderer.setPixelRatio(2);
        app.onResize();
    app.renderer.setPixelRatio(2) increases resolution by 2 times, without affecting the HTML layout.
    #9371
    justkmoo
    Thank you so much Ivan! It works perfectly! :good:
